PAGE
Create community slaves
The purpose of this page is to provide advices to create CloudStack linux templates ready to use for others as Community Templates.
The page is divided in 3 parts,
- what seems to be common to all linux Systems
- what is specific to Debian Systems
- what is specific to RedHat Systems
Community templates
Caution
When creating a qcow2 template, ensure that it follows the qcow2 v2 format, otherwise it won’t work on CI. You can generate such qcow2 file using the compat option of qemu-img like:
$>qemu-img create -f qcow2 -o compat=0.10 mytemplate.qcow2 10G
Previous steps
This document is intendend to be used once the base system is installed via iso. This part should be available somewhere else... If you need to create a user during system installation, one can use a user named template-user. Everything below this line should be run as root
Common
- Initialize root password (set ‘password’ as root password)
passwd
- Initialize ci account (default password is ‘ci’)
useradd -d /builds -m -p '$6$fasToP1b$X09p76wvP5L3rvVYQ.UAFghykr/Kn.EtuXyGT5wajifBq0hDNXDxZaJtzk2cUz/1gwstm.moka2/I9fwtp2gG1' -s /bin/bash ci
mkdir ~ci/.ssh
touch ~ci/.ssh/authorized_keys
chown -R ci:ci ~ci/.ssh
chmod 700 ~ci/.ssh
chmod 600 ~ci/.ssh/authorized_keys
- Create group admin and add ci user to this group
groupadd admin
gpasswd -a ci admin
Debian
- Update the system
apt-get update && apt-get dist-upgrade
- Install the common libraries and tools to the template
apt-get -y install openjdk-6-jre openjdk-6-jdk gcc g++ make gfortran cmake python-distutils-extra rubygems ruby-rvm subversion git-core python-numpy python-scipy python-matplotlib ipython mercurial bzr openmpi1.5-bin vim emacs scons ocaml
apt-get -y install whois
- Get the scripts to work with CloudStack Integration (set ssh key on instance create and allow dynamically modifying password)
wget --no-check-certificate
https://ci-cloud.inria.fr/cloud-set-guest-sshkey.in
-O cloud-set-guest-sshkey.in
https://ci-cloud.inria.fr/cloud-set-guest-password
-O cloud-set-guest-password
cp cloud-set-guest-password /etc/init.d/
chmod +x /etc/init.d/cloud-set-guest-password
update-rc.d cloud-set-guest-password defaults 98
cp cloud-set-guest-sshkey.in /etc/init.d/
chmod +x /etc/init.d/cloud-set-guest-sshkey.in
update-rc.d cloud-set-guest-sshkey.in defaults 98
- Clean the system
userdel -f -r template-user
echo '' > /etc/hostname
RedHat
- Add the admin group to sudoers
echo '%admin ALL=(ALL) ALL' >> /etc/sudoers
- Install common libraries and tools
rpm -ivh
http://fr2.rpmfind.net/linux/epel/6/i386/epel-release-6-7.noarch.rpm
yum -y install java-1.6.0-openjdk-devel gcc gcc-c++ gcc-gfortran make cmake rubygems subversion git numpy scipy python-matplotlib ipython mercurial bzr openmpi vim-enhanced emacs-nox scons ocaml
- Install rvm
yum install -y gcc-c++ patch readline readline-devel zlib zlib-devel libyaml-devel libffi-devel openssl-devel openssl make bzip2 autoconf automake libtool bison iconv-devel
curl -L get.rvm.io | bash -s stable
chkconfig --add cloud-set-guest-password
chkconfig --add cloud-set-guest-sshkey.in
- Clean the system
echo '' > /etc/udev/rules.d/70-persistent-net.rules
cat <
/etc/sysconfig/network-scripts/ifcfg-eth0
DEVICE="eth0"
BOOTPROTO="dhcp"
IPV6INIT="yes"
IPV6_AUTOCONF="yes"
NM_CONTROLLED="yes"
ONBOOT="yes"
TYPE="Ethernet"
EOF
sed 's/enforcing/permissive/g' -i /etc/selinux/config
sed -i 's/HOSTNAME=.*//' /etc/sysconfig/network
Common
Finally clean the root user bash history
echo > ~/.bash_history
