PAGE
Using Jenkins with Gitlab
Using Jenkins CI with a Gitlab Repository
Introduction
In this tutorial, we want to help the user to run the Jenkins Continuous Integration Service along the Gitlab platform. At the end of the configuration, your project will behave typically like :
- runs automatically jobs on CI/Jenkins when a commit is pushed on the master branch in Gitlab
- checkouts the changes in the sources of your Gitlab project
- perform the build of the project (code generation, compilations, tests, code inspection, etc.)
- sends a report about building to the Gitlab platform
There is another way to do that : using the Gitlab CI tool with gitlab-runners. In this case, the gitlab platform will be responsible for launching jobs on your VMs that your have to provide to gitlab. In this tutorial, we will not speak about this point of view : all the orchestration will be done by Jenkins CI
Prerequisites
- we assume that you know how to configurate a project on Jenkins, we will speak about how to adapt the process to the Gitlab platform
- we assume also that your have ever used the gitlab platform
Install plugins and configure plugins
- To work with the Gitlab platform, you need to install the following
Jenkins extensions
- Git plugin
- Gitlab plugin
- Not that if you have not ever installed the Git plugin and you select Gitlab plugin, Jenkins will select automatically to install the Git plugin
Check on the page https://ci.inria.fr/<nameOfTheProjectOnCI>/pluginManager/installed if the plugins are already installed, if not you can install them on the page https://ci.inria.fr/<nameOfTheProjectOnCI>/pluginManager/available
Gitlab plugin
- To configure that plugin, we need to generate a Secret Token on the Gitlab platform, to enable Jenkins to use the web API of Gitlab
Generate a API Token
- On Gitlab, click your account avatar, follow the sub-menu Settings, and select the tab Access Tokens
- Choose a name and an expiration date, select api, and click Create Personal Access Token
- DO NOT FORGET TO SAVE the content of the field Your New Personal Access Token to remember later.
Jenkins Credentials
- Go to Credentials, System, Global credentials (unrestricted) ( or https://ci.inria.fr/<nameOfTheProjectOnCI>/credentials/store/system/domain/_/ ) and click Add Credentials
- In the Field Kind, select Gitlab API Token and put the previously saved token, put gitlab-1 for ID and access your_login for Description, click Ok
Gitlab plugin Configuration
- On Jenkins, Go to Manage Jenkins, Configure System ( or https://ci.inria.fr/<nameOfTheProjectOnCI>/configure )and Go to the Gitlab section; Configure like in the screenshot, selecting Gitlab API Token for credentials. Click on Test Connection to make a small test
- Save your config
Retrieving the sources
Public project
In this case, you do not need to have a special credential to retrieve
the sources of your project
just add the
git@gitlab.inria.fr:<userGitlab>/<nameOfTheProjectOnGitlab>.git in
the Source Management section
Private project
Before, with Gforge, we use to create the Ghost user on the Gforge
platform corresponding
to the Jenkins user (see corresponding section of the
FAQ).
To do the same thing, we will use the deploy keys feature in Gitlab :
- first create a pair of public/private key on a slave (logged as ci )
cd /builds && ssh-keygen # without passphrase
- associate a git CI user on the slave, running on a shell for the user ci
git config --global user.name "CI" &&
git config --global user.email ci@dummyuser.ci.inria.fr
- Go on Gitlab, on your project select “Settings” menu, and in the submenu “repository”, you have a “Expand” button in the “Deploy Keys” subsection
- Choose a title, and copy paste the public key previously created (/builds/.ssh/id_rsa.pub)
- Click add key
- Go on Jenkins and add
in the field
Repository URL like in the image below:
- Do not take care about the warnings of Jenkins saying Failed to connect to repository : ..., but try the command and validate the key on the slave :
git ls-remote -h git@gitlab.inria.fr:/.git HEAD
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘gitlab.inria.fr,128.93.193.8’ (ECDSA) to the list of known hosts.
Launch Jenkins build automatically after a commit
- To launch a build automatically after pushing a commit on the repository, we need to set up a hook in Gitlab attached to our job of Compilation in Jenkins, To do that :
Jenkins Config
- Go in Jenkins , Select your Job, Configure, Go into the section Build Triggers
- Check that Build when a change is pushed to GitLab is checked
- Click on Advanced, and Generate : it generate a Secret token , copy into the Clipboard
Note: if your Jenkins is > 2.129, please be aware of the following security hardening : https://jenkins.io/blog/2018/07/02/new-api-token-system/
As Gitlab will connect as anonymous to Jenkins for hooks, anonymous requires read permission on your project. In Manage Jenkins, Configure Global Security ( or https://ci.inria.fr//configureSecurity/ ), add anonymous permissions to read - overall and read - job in the permission table.
Gitlab Config
- Click on , and Select Integrations
- Fill URL with an url of the form https://ci.inria.fr/<nameOfTheProjectCI>/project/<jobname>
- Paste your secret Token generated by Jenkins
- select Push Events and Merge Requests Events and Click Add Webhook
- you could manage to do a test with the Test button
Send build report to Gitlab
Now you want to receive a report of build (manage or failed) on the Gitlab platform :
- Add your sections of compilation, tests, etc.… (cf. the faq for that)
- Go into your job configuration on Jenkins, in the sub-section “Post Build Actions” and add Publish build status to GitLab commit into that section
- (Optional) : you can add a building compilation badge into the README.md of your project with code like that
[![Build status](https://gitlab.inria.fr/<userGitlab>/<nameOfTheProjectOnGitlab>/badges/master/build.svg)](https://gitlab.inria.fr/<userGitlab>/<nameOfTheProjectOnGitlab>/commits/master)
