PAGE
Introduction
The windows10-choco-java-virtio
template (in the Featured
tab) provides a Windows
10 installation with a native OpenSSH server and Chocolatey.
You may connect a fresh instance of this template via SSH or rdesktop.
SSH connections use the cmd.exe
as default shell. You may change
the default shell for Powershell, or the Cygwin
bash
, or the bash
provided by the Windows subsystem for
Linux.
Chocolatey is a package manager for Windows. You may use it to install the development tools that you need.
and many other packages.
Connect a slave via SSH
Add these lines to your ~/.ssh/config
file (by substituting
‹login›
with your actual login on ci.inria.fr
Host *.ci
ProxyCommand ssh -W $(basename %h .ci):%p ‹login›@ci-ssh.inria.fr
The following command connect the instance.
ssh ci@‹project›-‹slave›.ci
Connect a slave via rdesktop
The connection via rdesktop relies on an SSH tunnel to the rdp port.
ssh ‹login›@ci-ssh.inria.fr -L 3380:‹project›-‹slave›:3389
You may choose any other free port number instead of 3380
if you
want to open SSH tunnels to several slaves simultaneously.
If you obtain an error relative to bind
bind [::1]:3380: Cannot assign requested address
add a -4
to ssh to be sure to use IPV4 when connecting
rdesktop
can now be opened on that port on localhost
. rdesktop
is packaged by many distributions. For example, you may install it
with apt on Debian or Ubuntu, or homebrew[1] on Mac OS X.
[1] https://brew.sh/
With apt (Debian, Ubuntu, …):
apt install rdesktop
With homebrew (Mac OS X):
brew install rdesktop
For cut/copy/paste to work with rdesktop
on Mac OS X (within the
remote slave itself or between the remote slave and the client
machine), you may have to select the CLIPBOARD
selection as
target for the remote clipboard, by launching rdesktop
with
the following arguments.
rdesktop -r clipboard:CLIPBOARD localhost:3380
Change the default shell
The initial default shell when opening an SSH connection is
cmd.exe
. This default can be changed by setting the
string value DefaultShell
in the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\OpenSSH
For example, the following Powershell command line sets
Powershell as the default shell.
For more details about configuring OpenSSH, see
https://docs.microsoft.com/en-us/windows-server/administration/openssh/openssh_server_configuration
Warning: Jenkins expects cmd.exe
command line on Windows
environment. Making Powershell the default shell will prevent
Jenkins from using the agent.
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -PropertyType String -Force
Install Java runtime
The following command installs Java runtime, required for
Jenkins.
More details about javaruntime
package:
https://chocolatey.org/packages/javaruntime
choco install -y javaruntime
Install Git
The following command installs Git.
More details about Git
package:
https://chocolatey.org/packages/Git
choco install -y git
Install Microsoft Visual Studio
The following command installs a minimal setup for Visual Studio
2017 Community.
More details about VisualStudio2017Community
package:
https://chocolatey.org/packages/VisualStudio2017Community
choco install -y visualstudio2017community --execution-timeout=0
The following command installs Visual C/C++ compiler. Visual
Studio 2017 Community (or another base package) should have already
been installed before running this command. More details about
visualstudio2017-workload-nativedesktop
package:
https://chocolatey.org/packages/visualstudio2017-workload-nativedesktop
choco install -y visualstudio2017-workload-nativedesktop
The following command adds x64 native tools (e.g., the cl.exe
compiler) to the PATH
variable of the current shell environment.
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars64.bat"
Install Cygwin
The following command installs a minimal setup for Cygwin.
More details about Cygwin
package:
https://chocolatey.org/packages/Cygwin
choco install -y cygwin
Once Cygwin is installed, Cygwin packages can be installed
via choco
command line with option --source cygwin
For instance, to install GNU Make:
choco install --source cygwin make
The following command runs the Cygwin environment, which by
default provides a bash
command line.
C:\tools\cygwin\Cygwin.bat
The following Powershell command makes Cygwin the default shell for SSH connections.
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\tools\cygwin\Cygwin.bat" -PropertyType String -Force
If you already connect Jenkins to the agent, remember
to disconnect then reconnect from Jenkins to use Cygwin.
The remote working directory shoud be set to /cygdrive/c/builds
and you should create this directory before trying to connect
to the agent via Jenkins.
Install CMake
The following command installs CMake and add CMake
to PATH
for all users.
More details about cmake
package:
https://chocolatey.org/packages/cmake
choco install -y cmake --installargs 'ADD_CMAKE_TO_PATH=System'
You should run the Powershell command Reload-Service sshd
to get the new environment for subsequent SSH connections.
Moreover, if you already connect Jenkins to the agent, remember
to disconnect then reconnect from Jenkins as well.
Install Windows subsystem for Linux
The Windows subsystem for Linux is an optional feature, you
may enable it by installing the package wsl
https://chocolatey.org/packages/wsl
choco install -y wsl
You will probably have to restart Windows before being able to use the subsystem. If subsequent installations of some distributions fail, you may try to restart before trying again.
Alternatively, you may enable the feature in Powershell as administrator.
Enable-WindowsOptionalFeature -Online -FeatureName Microsoft-Windows-Subsystem-Linux
You may then install the distribution of your choice. Some examples:
choco install -y wsl-ubuntu-1604
choco install -y wsl-debiangnulinux
These packages have wsl
package as dependency: the
feature Windows subsystem for Linux will therefore be enabled
if required when you request to install these packages.
However, choco
appears not to restart Windows before
trying to install the distributions, leading their
installation to fail if you don’t restart Windows
yourself before.
The command ubuntu
launches Ubuntu default shell
(presumably, bash).
The Debian package does not appear to insert debian
command in PATH
; the command can be found in
C:\ProgramData\chocolatey\lib\wsl-debiangnulinux\tools\unzipped\debian.exe
The following Powershell command makes Ubuntu default shell the default shell for SSH connections.
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\ProgramData\chocolatey\bin\ubuntu.exe" -PropertyType String -Force
to disconnect then reconnect from Jenkins to use WSL.
The remote working directory shoud be set to /mnt/c/builds
You will have to install the Java runtime in the subsystem.
apt install default-jre
Configure Jenkins
To configure Jenkins launch method “Launch agent agents via SSH”:
- the “Host” field should match the hostname,
- the “Credentials” field should be the “ci/ci” login/password pair.
- the “Host Key Verification Strategy” should be “Manually provided key Verification Strategy”, and the associated “SSH Key” should be the content of one of the keys generated in
C:\ProgramData\ssh\*.pub
. You may copy the key locally before withscp
scp ci@‹project›-‹slave›.ci:'C:\ProgramData\ssh\ssh_host_rsa_key.pub' .
Note: it does not appear to be possible to use key authentication
and the credential “ci (Inria CI generic authentication to slaves)”.
Theoretically, the key is downloadable at the following URL:
https://ci.inria.fr/project/download/ssh/‹project›
and the public SSH key of the Jenkins instance should be added to the file
C:\ProgramData\ssh\administrators_authorized_keys
on the slave
(or C:\Users\ci\.ssh\authorized_keys
if the last lines of sshd_config
have been commented).
Moreover, the authorized_keys
file should have the correct permissions:
Microsoft provides a tool for that:
Set-ExecutionPolicy RemoteSigned
Install-Module -Force OpenSSHUtils -Scope AllUsers
Repair-AuthorizedKeyPermission C:\Users\ci\.ssh\authorized_keys
However, sshd keeps showing Authentication error
in the logs.
Disable automatic update via Windows Update service
Windows Update automatically detects, downloads and installs update for Windows, which can be useful, in particular for security updates. However, updating Windows often implies automatic restarts that can be unconvenient for continuous integration. Windows Update service can be disabled in Powershell with the following command:
Stop-Service wuauserv
Set-Service -Name wuauserv -StartupType 'Manual'
Resize disk
First, you have to resize the volume in Cloudstack: on the volume panel, click on the last button of the toolbar (with the tooltip “Resize Volume”). In the form, you can ignore the first line (“New Offering”) and supply the second line with a size in GB (“New Size (GB)”).
Then, you have to open a graphical connection to the slave to resize
the partition. Run diskmgmt.msc
, select the partition to resize (the
partition should be immediately on the left of the “Unallocated”
space), and choose “Extend Volume…” in the context menu. On the
second page of the assistant, copy in “Select the amount of space in
MB:” the value of “Maximum available space in MB”.
On some Windows installation, there may be a recovery partition
between the main partition and the unallocated space, which prevents
the main partition to be resized by the above method. You can delete
the recovery partition by using the command-line tool diskpart
instead of diskmgmt.msc
run
rescan
first -
then
list disk
, thenselect disk
n -
then
list partition
, thenselect partition
n -
then
delete partition override
