PAGE
These instructions explain how to recreate the windows-10
template
with OpenSSH server and Chocolatey.
Create a Windows 10 slave
This page supposes that a slave has been created in a project in
https://qlf-ci.inria.fr from one of the two templates Win10-CI-2-GTE
or windows-10
(Community
tab).
windows-10
template is derived from Win10-CI-2-GTE
with an Open SSH server and Chocolatey installed: these steps are
documented below.
Choose Medium instance-W10: 2x2 GHz + 4 GB RAM
for “Computer offering”.
Install OpenSSH Server
The setup procedure of OpenSSH Server on Windows 10 is documented on Microsoft’s website. https://docs.microsoft.com/en-us/windows-server/administration/openssh/openssh_install_firstuse
According to the page linked above, the procedure should work on Windows Server 2019 and from Windows 10 1809.
The installation can be performed with Powershell launched as administrator (search for Powershell in start menu, right-click on it, and choose “Run as Administrator”)
You may run the following command to check that OpenSSH.Server
capability is available and not installed in your system (note
that you should be able to copy/paste from your machine to the
Powershell console displayed by rdesktop
: just press Ctrl+V
to paste in the console).
Get-WindowsCapability -Online | ? Name -like 'OpenSSH*'
You should get the following output.
State : Installed
State : NotPresent
The following command installs the OpenSSH.Server
capability (if a different version number is displayed in the
output of the command above, you should copy the displayed
version number accordingly).
Add-WindowsCapability -Online -Name OpenSSH.Server~~~~0.0.1.0
In the case of the output displays RestartNeeded : True
, then
the slave should be restarted. You would then have to run
Powershell as administrator again.
To finalize the installation and start the sshd
service,
execute the following commands in Powershell.
Start-Service sshd
Set-Service -Name sshd -StartupType 'Automatic'
The initial default shell when opening an SSH connection is
cmd.exe
. This default can be changed by setting the
string value DefaultShell
in the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\OpenSSH
For example, the following Powershell command line sets
Powershell as the default shell.
For more details about configuring OpenSSH, see
https://docs.microsoft.com/en-us/windows-server/administration/openssh/openssh_server_configuration
Warning: Jenkins expects cmd.exe
command line on Windows
environment. Making Powershell the default shell will prevent
Jenkins from using the agent.
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -PropertyType String -Force
The following command restores cmd.exe
as the
default shell.
New-ItemProperty -Path "HKLM:\SOFTWARE\OpenSSH" -Name DefaultShell -Value "C:\Windows\System32\cmd.exe" -PropertyType String -Force
Note that you may always run the commands powershell
or cmd
to
enter into a Powershell or a Windows command line.
Install Chocolatey
The installation instruction are given on Chocolatey website. https://chocolatey.org/install
The following command has to be executed
in Windows command line (cmd.exe
) as administrator
and installs Chocolatey.
@"%SystemRoot%\System32\WindowsPowerShell\v1.0\powershell.exe" -NoProfile -InputFormat None -ExecutionPolicy Bypass -Command "iex ((New-Object System.Net.WebClient).DownloadString('https://chocolatey.org/install.ps1'))" && SET "PATH=%PATH%;%ALLUSERSPROFILE%\chocolatey\bin"
Surprisingly, choco
command seems to be available from ssh
sessions only after restart (Restart-Service sshd
is not enough).
Additional disks
Support for additional disks require installing virtio drivers.
These drivers are pre-installed in the windows10-choco-java-virtio
template.
The drivers are available for download: https://fedorapeople.org/groups/virt/virtio-win/direct-downloads/latest-virtio/virtio-win.iso
To download them with powershell
run
wget https://fedorapeople.org/groups/virt/virtio-win/direct-downloads/latest-virtio/virtio-win.iso -OutFile virtio-win.iso
run
Mount-DiskImage $pwd\virtio-win.iso
With usual settings, the disk should have been mounted on E:\
The installation wizard E:\virtio-win-gt-x64.msi
should be executed
graphically to get administrative rights.
Activate Windows 10
) as administrator
and activates Windows 10.
cscript c:\windows\system32\slmgr.vbs /ipk W269N-WFGWX-YVC9B-4J6C9-T83GX
cscript c:\Windows\system32\slmgr.vbs /skms kms.inria.fr:1688
cscript c:\Windows\system32\slmgr.vbs /ato
(The key W269N-WFGWX-YVC9B-4J6C9-T83GX
specifies that the edition is Windows 10 Pro
, see
https://docs.microsoft.com/en-us/windows-server/get-started/kmsclientkeys)
